FTP from Cisco IOS device failure
Jan 19th, 2010
Hi all,
I have FTP case, i suspected that what caused it
In my lab, Two Cisco 2811 connected together with back-to-back interface with clock rate 256Kbps
I tried to FTP file from flash memory of router to server but it not completed such as I would like to get file 1.5 MB from router but i received only 1.4 MB!!!
I tried to change the files size to smaller/ larger and change speed as well but i getted the same result. I did not sure this cause come from Router or IOS. Could anyone advice me about this case?
PS. I getted the code from FTP application, 221 Services closing control connection
      I transfer file between PC through these router, succeed
Sergei Vasilenko Wed, 01/27/2010 - 02:55
Hello Decho,
Which IOS version are you using this router?
From the description it could be anIOS bug,
for example:
CSCsx46421 File Transfer aborts with the Active FTP
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsx46421
You migth try to test the described Workaround:
Use Passive FTP ("ip ftp passive" on problematic router) for the FTP
file to be properly transferred.
and consider an upgrade to one of the release with the fix.
Sergey
