870 series routers
Jan 19th, 2010
Can anyone explain what happens when you install advance IP services IOS on a 870 series router that has 24MB of flash memory...
The documentation states that you need 28MB of flash memory on 870 series router to install advance IP services IOS,
however,
the advance IP services IOS size is less than 24MB so you have no problem installing it on your router.
I have tried some simple configurations on such a router without it being connected to a ADSL line and I could not find anything wrong
with the router...
Leo Laohoo Tue, 01/19/2010 - 12:57
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Marko,
It ain't the config you should watch out for.  When the router boots up, it will try to read the IOS.  The IOS will "expand" and, like cooking yeast, when the IOS finds out it can't be accomodate in the flash provided the router will stop the boot and sometimes with an error that the firmware is "corrupt".
marko.bozicevic Wed, 01/20/2010 - 00:50
Hi Leolaohoo,
That is exactly what I expected to happen,that the router will end up in rommon or something but every time it booted
successfuly...without errors.That is what is confusing me.
Here is the output of the show version:
_______________________________________________________________________________________________________________
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(11)T2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Tue 01-May-07 09:03 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
Router uptime is 0 minutes
System image file is "flash:c870-advipservicesk9-mz.124-11.T2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 878 (MPC8272) processor (revision 0x200) with 118784K/12288K bytes of memory.
Processor board ID FCZ1141R4RN
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ISDN Basic Rate interface
128K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Intel Strataflash)
and the show flash:
Router#sh flash:
Directory of flash:/
    2  -rwx    17227284   --- -- ---- --:--:-- -----  c870-advipservicesk9-mz.124-11.T2.bin
23482368 bytes total (6250496 bytes free)ž
The router seems to boot normaly every time...
Related Content
