MGCP Pri in Germany - DDI Problem -
keanej
Level 3
Level 3
I am having a problem with a PRI in Berlin, Germany.
People can ring from mobiles fine but when they ring from German landlines it fails.
So lets say the main number is 220 83720
The DDIs are 220 83720 01 - 99
Its a bit weird but basically the PRI is 8 digits and the extensions are 10 digits.
The main number works, but when you dialled a DDI say ending in 10, we were seeing 220 83721.
Now whats a bit wacky - it all works grand from a mobile, its only German landlines...
Now I configured
interface Serial0/0/0:15
isdn overlap-receiving
and I have enabled the 'Overlap receiving flag for PRI' in the service parameters.
Any ideas ??? Apparently its related to enbloc and overlap dialling.
Anyhelp greatly appreciated ..
FYI : The Telco have said
They found out that it always works when using Blockwahl and that it never works when using Einzelwahl. If you dial the number including the extension in one block (which is the case when you have the number registered on your phone (either Festnetz or mobile) then you always get through directly to the member of staff. If however you pick up the receiver and dial each number individually (Einzelwahl) then the call is interrupted after 030/220721- when dialing the next digit.
The cisco engineers have to configure the phone system in such a way that you can use Einzelwahl i.e. the system waits until all the digits are dialled/until the dialling is complete.
Deutsche Telekom cannot switch all incoming calls to enblock dialling because this is technically not possible.
Mr XXXX said something about this problem ocurring often with Cisco IP. Apparently Cisco IP is sometimes using a U.S. standard with certain timer settings that don't match with the German Telekom system. He said it would be best to ask the technicians at Cisco. They should be familiar with this problem and might know a solution.
21 Replies 21
Adam Thompson
Level 4
Level 4
I have seen this problem before, but our gateway was H.323 instead of MGCP. Have you tried manipulating the t302 timer on the ISDN overlap-receiving command? I would think it works the same way if it is applied to the D-channel of the PRI.
Syntax: isdn overlap-receiving t302 <
Example: isdn overlap-receiving t302 2000
Adam
Please rate if helpful
I tried that .. no joy - but thanks for giving it a go !!
Basically I am missing the last digit - I am not seeing it on the gateway when overlap dialling is being used. When enbloc dialling is used it works fine.
Here is the config - but I believe much of this is only used in H323 mode - I'm using MGCP and Backhaul. I have also included the call manager mgcp config in a file.
Many thanks for the help.
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
description Full PRA XXXXXXX
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn overlap-receiving T302 2000
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
voice-port 0/0/0:15
translation-profile incoming Trans-From-PSTN
translation-profile outgoing OutboundCallerPresentation
cptone DE
dial-peer voice 9 pots
description Dial 9 for PSTN
preference 1
destination-pattern 9T
incoming called-number .
fax rate disable
direct-inward-dial
port 0/0/0:15
By the way I have tried setting the service parameters
ccm service parameter - "Discard Non Inband Progress in Overlap Sending" to true.
ccm service parameter - "Overlap Receiving Flag for PRI" to true.
javascript:getHelp('OverlapReceivingForPriFlag')
Any ideas ??
The missing piece of the puzzle was
significant digits inbound must be set to ALL
also we had to reboot all the  call managers to get the
'Overlap Receiving Flag for PRI' enterprise setting to work ..  :-(
joanesga1
I have exactly the same problem on a PRI in Germany.
I have pointed Cisco TAC to your post.
Can you confirm which steps were required to resolve the issue ?
The service parameter for overlap receiving was already set to true.
I have then added overlap receiving to the serial interface
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn bchan-number-order ascending
isdn sending-complete
no cdp enable
I did have significant digits set to 4 - (last 4 to matchDN) but have changed this to all...
Was this everything ?
Many thanks for your post
here is a nice document which describes the problem:
http://www.cisco.com/warp/public/788/signalling/isdn_overlap_prob.pdf
I recommend to set the overlap receiving timer to 5000.
Also create a Translation Pattern which translates the number for example 030555.XXX (preDot discard) to the internal DN 912XXX.
Do not use the significant digits, because (mostly) in germany the 030555.0 is the number of the assistant =>
(0305550. (preDot discard) to internal 921100)
Kind regards,
Marcel Ammann
Many thanks Marcel
Issue is fixed
Summary of changes / config used to resolve issue..
changed T302 timer to 6000 (as below) and ensured overlap receiving enabled in CM service parameters (MGCP)
no ip address
encapsulation hdlc
isdn overlap-receiving T302 6000
isdn send-alerting
no cdp enable
Set E1 contoller to ALL significant digits in call manager
Added Translation in CM to 123.XXXX to then match DN XXXX
Used T in incoming dial peer to ensure timer used
dial-peer voice 1 pots
description DID processing peer
incoming called-number 123T
direct-inward-dial
Tested OK - Debug now shows additional missing digits being received
need debug isdn q931 and debug voip ccapi inout
This was a bit of a nightmare for us to be honest. The issue was that the extension digits were being sent in messages after connection in setup messages, rather than a typical dialled number.
The Three Things I needed to do to fix it were
1:
You need to set the Signigicant digits to all and the Prefix DN Blank.
If you point the CSS at a limited area you can process the digits in a custom manner
2:
System | Service Parameter | Server | Service:Cisco Call Manager | Overlap Receiving Flag for PRI = True
Change on all Call Managers - Reboot all call managers.
3:
controller E1 0/0/0
no ip address
encapsulation hdlc
no cdp enable
Thats what we ended up doing - hope that helps
James
PS: This is a bug, if sigificant digits is set - it is only processing connection digits rather than dialled digits - Cisco TAC view it as a config quirk - I disagree - it should be fixed in maintenance release.
Thanks James
Fortunately I didnt need to reboot the call maangers as the service parameter was already set to true
I agree the Significant digits field issue should be fixed....
I have asked tac to review this post and create documentation for others - as we only resolved this by finding your original post..
regards
Graham
Hi All -
I have this exact issue with a site in Germany using an MGCP gateway. My problem is I cannot get the last digit to come in. When I do a debug ISDN q931 I see the following:
Sep  7 08:31:36 UTC: ISDN Se1/1:15 Q931: RX <- SETUP pd = 8  callref = 0x0101
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18392
                Preferred, Channel 18
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x2180, '61964728442'
                Plan:ISDN, Type:National
        Calling Party Number i = 0x2183, '619647280'
        Called Party Number i = 0xC1, '907582'
                Plan:ISDN, Type:Subscriber(local)
Sep  7 08:31:36 UTC: ISDN Se1/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x 8101
        Cause i = 0x8081 - Unallocated/unassigned number
The DN on the phone is 6735824 and as you can see I am missing the last digit.
Heres what I have done so far:
Set the t302 timer to 5000. - no change
Removed the Significant digits and also the Prefix DN - still no change and also this stops all other calls from working so had to put this back on.
Can someone explain how I get the last digit to be sent to my gateway?
Hi Shane
Did you also set the service parameter to enable overlap receiving ?
Graham
Hi Graham,
Yes I have enabled this on the call manager servers already... I think my problem is in regards to the translation pattern?
Have you set incoming dial peer eg..
* Used T in incoming dial peer to ensure timer
used
direct-inward-dial
translation then needed to match received digits in CM if 4 digit ext
eg 123XXXX > XXXX
I do not have a dial peer as I am using MGCP...
