SA520 Multiple VLAN Subnet Question
Jan 19th, 2010
I am trying to configure my SA520 with 4 VLANS
VLAN-1 is configured as the default with 192.168.75.1/255.255.255.0 and DHCP Range of 192.168.75.100-254
I thought I could create VLAN 2,3, and 4 with the pattern of 192.168.x.1 and DHCP of 192.168.x.100-254 where x=the VLAN ID
When I do this, strange things seem to occur with connected DHCP clients on those VLANS, and I can not "see" DHCP leased clients in the config screen
The system happily accepted the above config.  So after reading the docs -- I noted that VLANS need to exist in the same DHCP scope.
I tried changing VLAN 2,3 and 4 to match the following pattern
VLAN IP = 192.168.75.x/255.255.255.0 with DHCP of 192.168.75.1x0->1x9
I get an error for the VLAN IP address stating that "IP in the same subnet is already configured"
Thoughts?
Firmware .39
Steven Smith Tue, 01/19/2010 - 09:14
Hi Jason,
Before the 1.0.39 firmware, the VLANs required the same subnet.  In 1.0.39, you can create your own subnets and DHCP scopes for each VLAN, which in fact is required in 1.0.39.  I am not sure if they will show up in the DHCP clients page, but I can look into this.
jason.w.frye Tue, 01/19/2010 - 09:23
Actually that maps to what I just tried.
The only real issue now seems to be that only VLAN 1 (default) DHCP clients show up in the list.
Related Content
