Cisco 800 Series Router
I have a Cisco 871 router running Cisco IOS 12.4(24).
I want to configure this device to terminate VPN connections from remote laptops using the Cisco VPN client. I have downloaded the latest version of the Cisco VPN client.
These laptops are running XP and MAC.
I want to use a pre-shared key for authentication.
Does anyone have an example of a config I can use or any advice on a direction I should take? Any pitfalls to avoid?
Jon Marshall Tue, 01/19/2010 - 11:41
[email protected]
There are quite a few examples of IPSEC configuration on the Cisco site. Start here and if you need further clarification then come back -
http://www.cisco.com/en/US/tech/tk583/tk372/tech_configuration_examples_list.html#anchor15
Jon
I did quite a bit of reading.
I am quite familiar with IPSEC, just not on Cisco's implementaion.
From bits and pieces, here and there, I have arrived to the following config.
It does NOT work.
PLEASE HELP......
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2010.01.27 01:47:28 =~=~=~=~=~=~=~=~=~=~=~=
show run
Building configuration...
Current configuration : 6045 bytes
version 12.4
no service pad
service password-encryption
hostname drw871
boot-start-marker
boot-end-marker
enable secret 5 -------------------------
enable password 7 -----------------------
aaa new-model
aaa authentication login default local
aaa authentication login userauth local
aaa authorization exec default local
aaa authorization network groupauth local
aaa session-id common
crypto pki trustpoint TP-self-signed-1963796551686
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1963796551686
revocation-check none
rsakeypair TP-self-signed-1963795651686
crypto pki certificate chain TP-self-signed-1963796551686
certificate self-signed 01
  quit
dot11 syslog
dot11 ssid office98
   vlan 1
   authentication open
   authentication key-management wpa
   guest-mode
   mbssid guest-mode
   wpa-psk ascii 7 -----------------------
dot11 ssid office98 guest-mode
   authentication open
--More--            wpa-psk ascii 7 -----------------------
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1 192.168.0.100
ip dhcp excluded-address 192.168.0.116 192.168.0.254
ip dhcp pool Internal-net
   import all
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   dns-server ----------------------- -----------------------
   domain-name dr.off98
   lease 4
ip inspect name MYFW tcp
ip inspect name MYFW udp
no ip domain lookup
ip domain name dr.off
ip name-server -----------------------
username capone -----------------------
username stiffer -----------------------
username scammer -----------------------
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp nat keepalive 20
crypto isakmp client configuration group Oschool
key mykey
pool OS-VPN
save-password
max-users 5
max-logins 2
crypto dynamic-map Oschool 10
reverse-route
crypto map SW-Client client authentication list userauth
crypto map SW-Client isakmp authorization list groupauth
crypto map SW-Client client configuration address respond
crypto map SW-Client 10 ipsec-isakmp dynamic Oschool
crypto ctcp port 443 10000
archive
log config
  hidekeys
bridge irb
interface Loopback99
ip address 192.168.99.1 255.255.255.0
interface FastEthernet0
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
ip access-group Internet-inbound-ACL in
ip inspect MYFW out
ip nat outside
ip virtual-reassembly
ip tcp adjust-mss 1460
duplex auto
speed auto
no cdp enable
interface Dot11Radio0
no ip address
no dot11 extension aironet
encryption vlan 1 mode ciphers tkip
broadcast-key vlan 1 change 45
ssid office98
ssid office guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2462
station-role root
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description Internal Network
no ip address
ip nat inside
bridge-group 1
interface BVI1
description Bridge to Internal Network
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip local pool OS-VPN 192.168.99.2 192.168.99.20
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 dhcp
ip nat inside source list 1 interface FastEthernet4 overload
ip access-list extended Internet-inbound-ACL
permit udp any eq bootps any eq bootpc
permit icmp any any echo
permit icmp any any echo-reply
permit icmp any any traceroute
permit gre any any
permit esp any any
access-list 1 permit 192.168.0.0 0.0.0.255
control-plane
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
scheduler max-task-time 5000
end
Thanks.......................
