Warning message
PIX 515E to block ip of a subnet
Answered Question
I have a pix
515E and would like to block traffic of certin ip subnets.
I am receiving so many hits from there to my email server SMTP port.
i manually blocked ip
Ex.
125.110.102.86    ip's from china and creating spam on my mail server.
220.190.41.132
insted of each ip i want to block 125.110.0.0 and 220.190.0.0
how can i get this done ?
Correct Answer by Jon Marshall about 7 years 7 months ago
[email protected]
thanx for the response jon
i am not alot fimilier with pix but from the web interface (PDM) i added rule like this and its blocking traffic from that ip
access-list acl_out_to_in line 40 extended deny object-group DM_INLINE_SERVICE_1 host 125.110.102.86 any 0x960c8531
  access-list acl_out_to_in line 40 extended deny ip host 125.110.102.86 any (hitcnt=21650) 0x47f4e704
  access-list acl_out_to_in line 40 extended deny tcp host 125.110.102.86 any (hitcnt=0) 0xe6059313
  access-list acl_out_to_in line 40 extended deny tcp host 125.110.102.86 any eq smtp (hitcnt=0) 0x7e703e53
what i would like to do is block everything from the ip 125.110.102.0 - 125.110.102.255 all hosts. is it possible ?
access-list acl_out_to_in deny tcp 125.110.102.0 255.255.255.0 any eq smtp
note instead of "any" you could actually put the SMTP server address - it's public IP.
If you want to deny all IP
access-list acl_out_to_in deny ip 125.110.102.0 255.255.255.0 any
but be aware that this will stop all IP connections from that subnet to any of your IP addresses.
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Tue, 01/19/2010 - 09:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
[email protected]
I have a pix
Ex.
220.190.41.132
Not sure what you are asking here.
If you are already blocking certain hosts eg.
access-list outside_in deny tcp host 125.110.102.86 host eq 25
then to block a subnet simply change the first bit of your acl ie.
access-list outside_in deny tcp 125.110.0.0 host eq 25
or have i misunderstood the requirement ?
Jon
Correct Answer
Jon Marshall Tue, 01/19/2010 - 09:28
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
[email protected]
Jon
