SA500 UPnP Memory Leak
Jan 19th, 2010
Looking at the release notes for firmware v1.1.21 I noticed that one of the known issues with this product line is a memory leak issue with UPnP.
I am looking to purchase new devices for my network and this product line is one that I'm looking into.
However, I plan to use UPnP extensivley on my network and will not purchase a device that has problems with it.
Is there a time frame for this memory leak to be fixed?
Something like a memory leak that can cause a device to lock up or reboot should be high priority to be fixed.
Steven Smith Tue, 01/19/2010 - 09:18
  • Gold, 750 points or more
The UPnP leak was found late in testing.  I don't have too much info on it, but I know they are looking to fix it soon.  I don't have a time frame and I believe the leak was small, but if you are using UPnP extensively, I would wait to avoid down time.
FratianiD Tue, 01/19/2010 - 17:22
Is there anyway you could provide a little more information?
I was looking specifically for a time frame.
Do I have to wait weeks or months or what?
Steven Smith Wed, 01/20/2010 - 07:26
Release dates are tentative, but I believe the next one is supposed to be less than 1 month away.
