ACS 5.0 Integration with Microsoft AD 2003
Jan 19th, 2010
While integrating ACS 5.0 with Microsoft AD i am facing error message (attached)..Can anyone help me on this??
AD is reachable from ACS..ACS is behind Firewall but ACS to AD all ports are open & vice-versa.
Erick Delgado Thu, 02/11/2010 - 09:05
Are you able to ping from ssh the DC dns name? Are you using an administratror account?
Please confirm
Erick Delgado Fri, 02/12/2010 - 08:30
The connection between the ACS and the AD is kerberos. Kerberos requires the ACS and the AD on the same timezone and the same time.
Please confirm that the DC time and date is the same as the ACS.
David Little Wed, 02/17/2010 - 15:11
Yes my time is correct.. just wanted to get that out of the way.......
Is anyone else have the issue when you are here
Users and Identity Stores >... >External Identity Stores >
Active Directory
and you click on the Select where it should open up a dialog window so you can browse your groups in AD that it just locks up and you can't browse??
I did some poking around hoping to see an error, but I can't find anything.  Is it just something with IE or is this some bug with this ACS??
