debug ppp negotiation output
Jan 19th, 2010
%LINK-3-UPDOWN: Interface Async7, changed state to up
As7 PPP: Treating connection as a callin
As7 PPP: Phase is ESTABLISHING, Passive Open
As7 LCP: State is Listen
As7 LCP: TIMEout: Time 0x1B5150 State Listen
As7 LCP: O CONFREQ [Listen] id 34 len 25
As7 LCP:    ACCM 0x000A0000 (0x0206000A0000)
As7 LCP:    AuthProto CHAP (0x0305C22305)
As7 LCP:    MagicNumber 0x109739EA (0x0506109739EA)
As7 LCP:    PFC (0x0702)
As7 LCP:    ACFC (0x0802)
As7 LCP: TIMEout: Time 0x1B593C State REQsent
As7 LCP: O CONFREQ [REQsent] id 35 len 25
As7 LCP: TIMEout: Time 0x1B6128 State REQsent
As7 LCP: O CONFREQ [REQsent] id 36 len 25
As7 LCP: TIMEout: Time 0x1B6914 State REQsent
As7 LCP: O CONFREQ [REQsent] id 37 len 25
As7 LCP: TIMEout: Time 0x1B7100 State REQsent
As7 LCP: O CONFREQ [REQsent] id 38 len 25
As7 LCP: TIMEout: Time 0x1B7908 State REQsent
As7 LCP: O CONFREQ [REQsent] id 39 len 25
As7 LCP: TIMEout: Time 0x1B80F4 State REQsent
As7 LCP: O CONFREQ [REQsent] id 40 len 25
As7 LCP: TIMEout: Time 0x1B88E0 State REQsent
As7 LCP: O CONFREQ [REQsent] id 41 len 25
As7 LCP: TIMEout: Time 0x1B90CC State REQsent
As7 LCP: O CONFREQ [REQsent] id 42 len 25
As7 LCP: TIMEout: Time 0x1B98BC State REQsent
As7 LCP: O CONFREQ [REQsent] id 43 len 25
As7 LCP: TIMEout: Time 0x1BA0A8 State REQsent
As7 LCP: O CONFREQ [REQsent] id 44 len 25
As7 LCP: TIMEout: Time 0x1BA890 State REQsent
%LINK-5-CHANGED: Interface Async7, changed state to reset
As7 LCP: State is Closed
As7 PPP: Phase is DOWN
%LINK-3-UPDOWN: Interface Async7, changed state to down
Help
Richard Burts Fri, 01/22/2010 - 06:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
It is not clear from this output what the problem is. Here are some things that need clarification and some observations.
- has this worked before and then stopped working? Or is this a new thing that has not worked before?
- one of the beginning messages indicates that this is treated as a callin. Do you know who initiated the call? Do you know what kind of device and how it is configured that initiated the call?
- what kind of router is this? what kind of device/card is Async7? How is it configured?
- Async7 implies that this is an analog device. Is the calling device also analog? Or is it possible that the calling device is some digital/ISDN device?
- the output indicates that your device is making numerous attempts to initiate negotiation  (As7 LCP: O CONFREQ [REQsent]) and every attempt to initiate negotiation times out. This suggests some incompatibility with the calling device. Is it using PPP? Is it configured for CHAP authentication?
Rick
hdoramane Fri, 01/22/2010 - 10:02
Dear All,
I was able to solve the issue by adding the following command to line 1:
modem autoconfigure type usr_courier.
I was using the default modem cap.
Thank you.
Richard Burts Fri, 01/22/2010 - 11:41
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
I am glad that you got the issue resolved. Thank you for posting back to the forum indicating that the problem was solved and what you did to solve it. It makes the forum more useful when people can read about a problem and can then read what was done that successfully resolved the problem.
It would also help readers to know that this thread has useful information if you would mark this problem as solved.
Rick
