"Write Net" command on PIX515e
HMidkiff
Hello:
I have a PIX515e.  I am doing some DR testing on a stand-buy unit.  When I issue the "write net" command to restore a backed up config from a TFTP server I keep getting a message that says "Not allowed to overwrite existing files".
Any advice would be helpful.
Harrison Midkiff
Jon Marshall
HMidkiff wrote:
Hello:
Harrison Midkiff
Harrison
"write net" does not restore  a backed up config from a TFTP server, it writes the config to a TFTP server. You error message is to with the TFTP server not the pix ie. the TFTP server does not have the correct permissions to allow you to overwrite the file.
Jon
Jon Marshall
HMidkiff wrote:
Hello:
Harrison Midkiff
Harrison
Jon
Jon:
Thanks for replying.  That was it.  "Configure net" is what I needed.  Once I read your reply I know where I went wrong.
Thank you again for replying to my post.
Harrison Midkiff
HMidkiff wrote:
Jon:
Harrison Midkiff
Harrison
No problem, glad to have helped.
Jon
Kureli Sankar
http://www.cisco.com/en/US/docs/security/pix/pix63/command/reference/tz.html#wp1027782
The following example specifies the TFTP server and creates a file named new_config in which to store the configuration:
tftp-server 10.1.1.2 /pixfirewall/config/new_config
write net :
A filename you specify to qualify the location of the configuration file on the TFTP server named in server_ip. If you set a filename with the tftp-server command, do not specify it in the write command; instead just use a colon ( : ) without a filename.
Many TFTP servers require the configuration file to be world-writable to
write to it.
Have you tried to use "copy tftp flash:" command?
Give that a shot.
-KS
