ipv6 policy routing on a 12410 running 12.0(32)SY?
Answered Question
Jan 19th, 2010
hi,
   Does anyone know if 12.0(32)SY code will ever support ipv6 policy routing?  I'm running 12.0(32)SY6 and on a 4GE-SFP-LC card in a 12410.  I looked for the 'ipv6 policy' command but it isn't there?  I tried 12.0(32)SY10 in the lab with the same result.
   Maybe someone can tell me if ipv6 policy routing is ever going to be supported in 12.0(32)SY code?  Is there somewhere else I can look for information about what features will be included in future IOS versions?
thanks,
Andy
Correct Answer by Giuseppe Larosa about 7 years 2 days ago
Hello Andrew,
according to feature navigator
http://www.cisco.com/go/fn
search by feature, IPV6 Policy Based Routing, the most powerful platform supporting it is C7600 with RSP720 and MSFC4.
it should not be supported on standard sup720 and not supported on 12410 with any IOS image.
I'm afraid that here the maximum size of TCAM tables counts. IPv4 PBR can be implemented because involves 32 bits addresses.
the TCAM entry for IPV6 PBR would require at least  128 bits + 128 bits + 128 bits (next-hop).
Doing this in software is not an option on this kind of devices.
SW based routers like ISR support it.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Tue, 01/19/2010 - 14:51
Hello Andrew,
Hope to help
Giuseppe
