How to monitor connections dropped and rejected on the PIX/ASA firewall?
Answered Question
Jan 19th, 2010
I need to monitor OID SNMP of the connections dropped and rejected on the PIX and ASA firewall. Is it possible?
If it is, which OID SNMP should I to monitor?
Correct Answer by Panos Kampanakis about 7 years 4 months ago
Syslogs and Netflow (introduced in 8.2 version) are your options.
No MIB can give you the conn numbers.
PK
Overall Rating: 5 (1 ratings)
Farrukh Haroon Wed, 02/03/2010 - 01:59
  • Red, 2250 points or more
Do you just want the count (number)?
Syslog would be the way of choice to get insight into these connections and not SNMP. I don't think any SNMP MIB is supported offering this functionality.
Farrukh
fjmendonca Wed, 02/03/2010 - 12:31
Yes, I need only the count (number) of connections dropped and rejected.
Correct Answer
Panos Kampanakis Wed, 02/03/2010 - 16:15
  • Cisco Employee,
PK
