probleme install 7960 with 7914
Jan 19th, 2010
Hi;
i install a Cisco 7960 phone for the Operator and i add 2 Cisco 7914; i add same id to the line off the 7914.
the probleme is the LED off the 7914 don t show the status off ID phones.
how can i resolved this probleme?
Thanks for your help
steigja Tue, 01/19/2010 - 17:34
Are you adding just SD's to the 7914's?  You need to add BLF SD's to see the status of the line.  You should also assign a SUBSCRIBE Calling Search Space to each phone,  I have seen adding this fix the problem.  You definitly need them to be BLF SD's.
Related Content
