Changing IP for Supervisor Desktop
Jan 19th, 2010
I have downloaded and installed the Supervisor Desktop from an IPCC server that had its IP address changed.  Now when I try and run the Supervisor Desktop it fails and the log file shows it is trying to log into the previous IP.  How can I change this?
Soman Nair Wed, 01/20/2010 - 00:42
Pls open registry of the supervisor desktop machine Start>Run>Regedit. and replace the following parameters with new IP or hostname. It should resolve your issue.
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems, Inc.\CTI Desktop\CtiOs
  Data:            Hostname/IP address of new CTIOS-A side server
Data:            Hostname/IP address of new CTIOS-B side server
Let the port number remain unchanged if it was not changed.
Gd luck.
Soman Nair.
(Pls rate if this was helpful)
Jonathan Schulenberg Wed, 01/20/2010 - 05:57
  • Cisco Designated VIP,
    2017 IP Telephony
If this is IPCC Express (CCX), you can use C:\Program Files\Cisco\Desktop\bin\PostInstall.exe  to make this change.
jgentsch Wed, 01/20/2010 - 14:18
I ran the post install right after I changed the IP address but before I downloaded the supervisor desktop
Jonathan Schulenberg Wed, 01/20/2010 - 14:20
    2017 IP Telephony
Run postinstall.exe on the workstation that you installed CSD on.
jgentsch Wed, 01/20/2010 - 13:19
CTI Desktop is not available in my registry where you stated.
Related Content
