SPA525G - But where do I set the string serv=tftp://192.168.2.2/;d0=English-US;x0=spa525_EN_7_2_5.xml;d1=German;x1=spa525_DE_7_2_5.xml
Jan 8th, 2010
Hi Patrick,
i´m still trying to localize my 525G, too.
But my Web-GUI of the 525G is in r/o-mode
and i can´t set any command like
(I´m a newbie on UC500 and have no further idea)
By the way, i want to localize several 521, too
but i can´t find the mentioned file CP_521_524_Dictionary.tar
from other topics. (cco-account is at hand)
Any idea?
Kind regards,
DetNit
Hi, now i´ve found the "WEB-Server writable"-button !!!
(Firmware 7.4.3)
serv=tftp://192.168.2.2/;d0=English-US;x0=spa525_EN_7_2_5.xml;d1=German;x1=spa525_DE_7_2_5.xml ???
Kind regards,
DetNit
DetNit1101 Tue, 01/19/2010 - 00:17
Hi @ all,
the first way was a dead-end for me and I got another hint:
For language "german" I puth both files
     spa525_DE_7_2_5.xml
     spa525_EN_7_2_5.xml
in the following directory
     flash:/phones/525/
and put following strings to the config of the UC520
     tftp-server flash:/phones/525/spa525_DE_7_2_5.xml alias German_Germany/525G-dictionary.xml
     tftp-server flash:/phones/525/spa525_EN_7_2_5.xml alias English_United_States/525G-dictionary.xml
and it works!
additional info: Firmware 7.4.3 can work with dictionary 7_2_5
Thanx to RaLe !!!
Greetings & happy Copy&Paste,
  DetNit
ROBERTO TACCON Tue, 02/02/2010 - 05:41
I'm trying to localize in Italian the PHONE 525G with firmware version 7.4.3.
My TFTP server IP is 192.168.1.55
My IP PHONE 525G IP is 192.168.1.4
I've put the spa525_EN_7_2_5.xml and the spa525_IT_7_2_5.xml files on the TFTP server.
Using the web browser on the PHONE 525G (192.168.1.4) I've configured the following string on the following menu (using admin login and advanced option):
Voice
Regional
Language
serv=tftp://192.168.1.55/;d0=English-US;x0=spa525_EN_7_2_5.xml;d1=Italian;x1=spa525_IT_7_2_5.xml;
BUT THE PHONE LOAD THE ENGLISH version.
I can see on the phone on the menu the option to use the italian language but the PHONE doesn't change it (still remain in english).
Can someone help me ?
Roberto Taccon
DetNit1101 Tue, 02/02/2010 - 06:09
Hi Roberto,
forget the way with serv:= and try this way
Put these additional strings into your UC-Config. Make sure to use the right names for the directories.
(I´ve changed language/country from German_Germany to Italian_Italy ?but I don´t know your according directories on the UC
in which the files are located)
     tftp-server flash:/phones/525/spa525_IT_7_2_5.xml alias Italian_Italy/525G-dictionary.xml
If the phone now is requesting the localisation "Italian_Italy/525G-dictionary.xml" then the UC provides the file
"flash:/phones/525/spa525_IT_7_2_5.xml" means
It works - in my case ...  :-)
Please check for the right name-settings for Italy
Greetings, DetNit
ROBERTO TACCON Tue, 02/02/2010 - 06:32
I haven't the UC . I use "only" SIP IP phones (generally prefer SNOM phones) because I'm using an external internet SIP provider.
Roberto Taccon
Joachim Kern Fri, 02/05/2010 - 02:53
serv=tftp://192.168.16.100/;d0=English-US;x0=spa525_EN_7_2_5.xml;d1=Italian;x1=spa525_IT_7_2_5.xml;
I used the string above. Worked for me with firmware 7.4.3.
The phone loads the xml files from the tftp server when you actually select the Italian language for the first time on the phone display.
Check your tftp server when you actually select Italian on the display and press the SAVE softkey.
