Ingree and Egress Gateway Pros and Cons
Jan 19th, 2010
Hi All,
I need to know the pros and cons of a Gateway if we are deploying it .
1. 1-Line Model (Both Ingress & Egress)
2. 2-Line Model (Sperate Ingress and Egress).
and your recommendation which model is better.
Br,
Sheeraz.
Muhammad Amir Raza Thu, 01/21/2010 - 02:08
That's depend on deployment model, if you are designing a single centerlize side then single Ingress and Egress is recommended.
Sheraz Saeed Lodhi Thu, 01/21/2010 - 21:57
Guys Thanks for reply,
Infact my question was, if we need to deploy 2 VGs and have a choice to deploy both gateways performing both functionalitis in it (Ingress & Egress) rather deploying them in 2-Line Model i.e. 1 Vg work as a Ingress and the 2nd as an Egress VG. So what are the pros and cons of these scenarion.
Any way i found some pros and cons.
Thnx
Related Content
