Router Log
Jan 19th, 2010
Hi All,
I would like to see who was login to router and when.
Is there any file I can see in router that log the login event.
Thanks for your suggestion.
Panos Kampanakis Wed, 01/20/2010 - 16:04
That info is not logged into a file in the router.
You might have logs for it. You can do show logg" to see if you have any info.
If not then you need to account for the vty line and also do "aaa authentication" so that these will be logged to a syslogs server.
I hope it helps.
