TACACS Administration issue in Cisco ACS V4.1
Jan 20th, 2010
I am using Cisco Secure ACS V 4.1 for windows. When takingTACACS+  Administration report, report is not getting generated. I have come to know that this is a Bug in this version so as per the support forums they have suggested to update to ACS- which shows this is given below.
For the same i have searched in cisco but this particular version is not present. enstead ACS is present.
Please let me know if i update ACS will it resolve this TACACS+ administration report issue. else provide me the remedy to fix this issue.
Jagdeep Gambhir Wed, 01/20/2010 - 07:02
That link does not have any full software listed, only patch are listed. This bug is fixed in ACS accumulative patch which can be downloaded from that link.
Incase you want to upgrade ACS, you need to open a TAC case to get the full software.
Do rate helpful posts
