Custom Background Images in Cisco IP Phones.
Answered Question
Jan 20th, 2010
HI,
I have a custom backgroung image workin on my cisco IP Communicator. I have several other models of phone in my office like 7965, 7970, 7975 etc. When I checked to change the custom background image in other phones I cant see the same image in the other phone models . Why is this. How can I can I make the same image availble to other phones also.
Do we need to create specific XML file for each model of phones.?
Faizal
Correct Answer by Jaime Valencia about 7 years 2 months ago
Background questions have been asked PLENTY of times before, you can find the info for ANY model in ANY CUCM version if you search NetPro.
PLEASE SEARCH Netpro for answers before posting.
7941 / 7961
Full size image— 320 pixels (width) X 196 pixels (height).
Thumbnail image— 80 pixels (width) X 49 pixels (height).
Directory "Desktops/320x196x4"
7942 / 7962
Full size image—320 pixels (width) X 196 pixels (height).
Thumbnail image—80 pixels (width) X 49 pixels (height).
Directory "/Desktops/320x196x4"
7945 / 7965
Full size image—320 pixels (width) X 212 pixels (height).
Thumbnail image—80 pixels (width) X 53 pixels (height).
Directory "/Desktops/320x212x16"
7970 / 7971
Directory "Desktops/320x212x12"
7975
Full size image—320 pixels (width) X 216 pixels (height).
Directory "/Desktops/320x216x16"
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Correct Answer by jilfersalam about 7 years 2 months ago
Yes. You need to make different images with different Xml's and upload them to the specifc directories.
7965/7945 -
Folder - /Desktops/320x212x16
• Full size image—320 pixels (width) X 212 pixels (height).
• Thumbnail image—80 pixels (width) X 53 pixels (height).
7975
Folder - /Desktops/320x216x16
• Full size image—320 pixels (width) X 216 pixels (height).
hope that helps
Overall Rating: 5 (2 ratings)
faizal_vi Wed, 01/20/2010 - 05:01
Hi Jilfer,
Thanks for you reply. It seems that the folder name and file is same for 7965 and 7975. How is this possible.?
Faizal
jilfersalam Wed, 01/20/2010 - 05:09
The folder names are different. I have edited the full size image size it should be 320X216 for 7975
Correct Answer
Jaime Valencia Wed, 01/20/2010 - 06:42
  • Cisco Employee,
  • Hall of Fame,
    2011
7941 / 7961
7942 / 7962
7945 / 7965
7970 / 7971
7975
java
Correct Answer
jilfersalam Wed, 01/20/2010 - 04:53
7965/7945 -
7975
hope that helps
