Ciscoworks Group Filtering issue
Jan 20th, 2010
We currently have an issue on LMS 3.1 whereby we have created a new group from within Common Services -> Group Admin.  We have given the group the following attributes:
* Group Name: xyz
* Membership Update:  Automatic
* Visibility Scope: Public
Within the rule expression we are trying to filter using:
* Variable: ManagementIPAddress
* Operator: range
* Value: x.y.z.[0-255]
This is accepted and moves onto the Membership screen.  At this point it lists under "objects from parent group:" all the devices stored in the DCR and not the devices that match the filter rule specified above.
Is there something else we need to consider in order to get the filter to work as we would expect ?
Many Thanks
Joe Clarke Sat, 01/23/2010 - 09:47
Nope, that rule looks okay.  Just make sure these devices have the correct management IP filled in within DCR.  If you are only using hostnames in DCR, then this rule will not match anything.
