CallManager 5.1.3 put digit in front phone number
Jan 20th, 2010
  • " /> Participante em Destaque,
    Prêmio"Escolha dos membros": novembro de 2014
Hi Guys,
The Carrier ask for me if it is possible the CallManager send digits before number Phone. For example:
The User dial 8XXXXXXX and CallManager send for example 0118XXXXXXX for gateway and the gateway send the same number and the Carrier strip the 011, sending only 8XXXXXXX. This test was request by carrier, because, the number Celular Phone is finishing.
Wilson Santana
htluo Wed, 01/20/2010 - 05:17
  • Red, 2250 points or more
You may go to CUCM Admin > Call Routing > Route/Hunt > Route Pattern.  You should already have a pattern 8XXXXXXX.
Click on the patterh 8XXXXXXX.  There's a block called "Called Party Transformations".  In the block, you may put 011 in "Prefix Digits (Outgoing Calls)".
Hope this helps.
Michael
http://htluo.blogspot.com
Jonathan Schulenberg Wed, 01/20/2010 - 05:24
  • Cisco Designated VIP,
    2017 IP Telephony
If you upgraded to UCM 7.x you would gain the ability to perform this transformation on the individual circuit instead of cluster-wide. UCM 7 supports adding a Called Party Transformation CSS on the circuit/trunk. This is part of the E.164 dial plan design but you could use it for your purposes just as easily.
