Can I change my certification name?
Jan 20th, 2010
I want to request shipping for my CCNA certificate, but before that, I need to change my name (I registered with the name which wasn't my full name because it must be adjusted with the name in my ID card). So, is it possible? (I can't find the option to change my name, only my address or telephone number that can be changed) Thanks.
Ganesh Hariharan Thu, 01/21/2010 - 02:45
For your query cisco certifictaion support is the best place.They will tell you the exact answer for your query.
Ganesh.H
