CM Reporting
Answered Question
Jan 20th, 2010
Morning, Is there any way to report on which phones have Mobility ena
bled in CM 7? I have 3 users with mobility enabled who are not associtaed to phones, they are taking up 4 DLU's when they should only take 2 while associated with a phone. Since we have thousands of users, searching will be difficult.
Liam
Correct Answer by Michael Owuor about 7 years 5 months ago
Hi Liam,
To find out all users who have mobility enabled, run the following from the SSH command line on the Pub:
run sql SELECT userId, enableMobility FROM EndUser WHERE enableMobility = 't'
Hope this helps.
Michael.
Overall Rating: 4 (2 ratings)
Jaime Valencia Wed, 01/20/2010 - 06:47
  • Cisco Employee,
  • Hall of Fame,
    2011
No native reporting for that, you would need to go thru the database dictionary to find which field determines this and then run qrys to the informix DB.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Correct Answer
Michael Owuor Wed, 01/20/2010 - 07:12
  • Cisco Employee,
Hi Liam,
Hope this helps.
Michael.
walshliam Wed, 01/20/2010 - 07:44
Thank you both for the info. Michael, the sql query command worked great! thanks so much.
Liam
