SRST on CM 6.0
Hello, im running a lab enviroment, i want to implement srst tm cm ip is 192.168.1.10, the default gateway and router on wich i want to enable srst is 192.162.1.1, i use on the router the commands
call-manager-fallback
ip source-address 192.168.1.1
and max ephones/dn
but it doesnt work, it doesnt appear on device configuration and when the cm is down there is no fallback
am i missing something??
Thanks in advance
Cesar
Jaime Valencia
Have you created the SRST reference and assigned to the DP??
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
nope, because i was using the default gateway, but i checked there and was set to disabled, so THANKS A LOT
