BAT 5.3(2) Phone Template Insert... Remote Scripting Errors
Jan 20th, 2010
Hello everyone,
I was attempting to import Phones/Users using BAT 5.1 and every time I would try to insert a new phone template, it would give me the error "Error No.    " and nothing else.
I upgraded to BAT 5.3(2) and now when I got to insert a new phone template I get the following errors:
Dialog box: Cannot locate proxy which supports remote scripting. Was RSEnableRemoteScripting method invoked?
Dialog box: Failed to create ASP object for :_RemoteScripts/rs_InsertFromFile.asp
Dialog box: Failed to create ASP object for :_RemoteScripts/rs_UpdateDelete.asp
DBLX.FastAccessX.1 error '80040640'
CDBLException Dump: [ODBC Error]: Error executing  "SELECT 'recCount'=count(*) FROM CommonProfile": [Microsoft][ODBC SQL Server  Driver][SQL Server]Invalid object name 'CommonProfile'.
/BAT/includes/elements.asp, line 459
I've tried both locally and through remote desktop, also tried in Firefox, IE and Chrome and all produce the same errors.
thierry.berwart_2 Mon, 02/01/2010 - 03:56
I have also this error with BAT 5.2(3e)  (CCM 4.2(3)SR4B) :
ERROR:
Cannot locate proxy which supports Remote Scripting.
Failed to create ASP object for : _RemoteScripts/rs_BATNumPlan.asp
Did you find a solution ?
Kind regards,
Thierry
Related Content
