01-20-2010 09:10 AM - edited 03-14-2019 05:08 AM
Does anyone know if an SRND exists for Cisco Quality Management? Or if not, links to any docs?
Solved! Go to Solution.
01-20-2010 11:08 AM
I don't think they call it SRND for the WFO products. You can find what you require from the following http://www.cisco.com/en/US/partner/products/ps8293/products_implementation_design_guides_list.html
Thanks!
-JT-
01-20-2010 11:08 AM
Thanks!
-JT-
