Route and name
John Blakley
All,
Is the name at the end of the "ip route" command just used as an identifier? I don't think it affects routing in any way, does it? We're adding floating routes to some of our routers, and we're wanting to name these.
John
HTH, John *** Please rate all useful posts ***
Peter Paluch
Hello John,
Yes, the name is for identification purposes only. The IOS 12.4T Command Reference guide contains this description for the ip route command:
The name next-hop-name keyword and argument combination allows you to associate static routes with names in your running configuration. If you have several static routes, you can specify names that describe the purpose of each static route in order to more easily identify each one.
Best regards,
Peter
Peter Paluch
Hello John,
Best regards,
Peter
That's what I thought Thanks Peter!
