Syslog Message: %SIP-3-UNSUPPORTED: Unsupported ptime value
Answered Question
Jan 20th, 2010
Receiving syslog message :%SIP-3-UNSUPPORTED: Unsupported ptime value.  But we have no SIP-related commands in our config. We reloaded router Friday eve 1/15 but two more %SIP-3-UNSUPPORTED: Unsupported ptime value messages re-appeared on 1/18. The router in question is a 3745 running c3745-a3jk9s-mz.123-14.t7.bin. This router does have one interface facing an ISP. Any suggestions?  Thanks.
Correct Answer by Laurent Aubert about 6 years 12 months ago
SIP is enabled by default so if you don't need it, you can use the following command to stop this service:
sip-ua
 no transport udp
 no transport tcp
 no transport tcp tls
To check if SIP is enabled, you can use the following commands:
Router#show processes | include SIP
     149 Mwe 40F48254            4          1    400023108/24000  0 CCSIP_UDP_SOCKET
     150 Mwe 40F48034            4          1    400023388/24000  0 CCSIP_TCP_SOCKET
or
router#sh ip sockets
Proto    Remote      Port      Local       Port  In Out Stat TTY OutputIF
 17 0.0.0.0             0 10.16.60.5       5060   0   0  211   0
 17 10.1.57.53        514 10.16.60.5      58917   0   0   10   0
 17 10.1.57.55         49 10.16.60.5         49   0   0   11   0
 17 10.1.57.56         49 10.16.60.5         49   0   0   11   0
 17 0.0.0.0             0 10.16.60.5       2517   0   0    1   0
 17 10.1.74.49       1757 10.16.60.5        161   0   0    1   0
Laurent.
Overall Rating: 5 (5 ratings)
Correct Answer
Laurent Aubert Wed, 01/20/2010 - 18:57
sip-ua
 no transport udp
 no transport tcp
or
Laurent.
steve.rand Thu, 06/30/2011 - 01:51
Seems to have solved my problem too! Thanks!
*Jun 30 18:13:57: %SIP-3-UNSUPPORTED: Unsupported ptime value
*Jun 30 18:17:05: %SIP-3-UNSUPPORTED: Unsupported ptime value
*Jun 30 18:20:17: %SIP-3-UNSUPPORTED: Unsupported ptime value
*Jun 30 18:23:23: %SIP-3-UNSUPPORTED: Unsupported ptime value
*Jun 30 18:26:28: %SIP-3-UNSUPPORTED: Unsupported ptime value
*Jun 30 18:29:39: %SIP-3-UNSUPPORTED: Unsupported ptime value
*Jun 30 18:32:51: %SIP-3-UNSUPPORTED: Unsupported ptime value
*Jun 30 18:35:53: %SIP-3-UNSUPPORTED: Unsupported ptime value
*Jun 30 18:38:10: %SYS-5-CONFIG_I: Configured from console by srand on vty0 (10.3.12.100)
#               show clock
*18:41:00.851 aest Thu Jun 30 2011
It was occurring every three minutes, but no longer!
-Steve
ahmad82pkn Thu, 05/24/2012 - 07:48
Hello All,
i have same issue, actually my router is on Edge, and is acting as pass through for VOIP / SIP calls from my asterisk server to Internet base VOIP provider.
soo if i disable this service on router, will it casue pass through to stop working as well? any thoughts?
aedamasceno Thu, 07/18/2013 - 07:07
I am having the same issue, but I am actually using CME as SIP, and that message is really annoying. Not to mention that when the customer sees it, he's gonna ask me what that is and I have no clue what to answer. I already looked it up, but all I can find is this post and things that don't explain about this error.
All I need to do is stop the message from showing. Any ideas?
