Hotdial on CUCM
dmotloch
Has anyone found a better way to do hot dials instead of using a blank translation pattern in a unique partition?
I'm concerned about a tech making a mistake while setting up the hot dial's blank translation -- and impacting our cluster.
Jaime Valencia
That's the only way in CUCM, otherwise it would require user interaction or waiting for the interdigit timeout to match the blank TP.
Have your tech practice the config before letting him do the procedure on the live environment, make sure he understands why it works that way so in case of trouble he knows where to look.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
