Network Device Discovery.
Answered Question
Jan 20th, 2010
I have one Ciscoworks server with the following.
Common Services 3.1.0
Campus Manager 5.0.0
Cisco View 6.1.6
Default Device Manager 3.0.0
IPM 4.0.0
RME 4.1.0
I only installed this yesterday. I am having issue with Device Discovery where I put in the IP Address of our 6509 switch and put in the IP Address range (for example 10.2.0.0) for it to scan. However it is returning no results. I have added in the SNMP settings.
Is there anything I might be missing.
Anthony.
Correct Answer by Joe Clarke about 7 years 5 months ago
Ugh, LMS 3.0.  You really should upgrade to LMS 3.0.1 which dramatically changes the way Discovery works.  You can download LMS 3.0.1 from http://www.cisco.com/cgi-bin/tablebuild.pl/lms301 .  Once done, apply the consolidated Discovery patch from CS 3.1.1 from http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-cd-one .  After that, configure Common Services Discovery under Common Services > Device and Credentials > Device Discovery as desired.  If you use CDP as the discovery method, make sure your seed device has CDP neighbors, and double-check the SNMP settings to make sure they match what is configured on the device.
Overall Rating: 4 (1 ratings)
Correct Answer
Joe Clarke Sat, 01/23/2010 - 10:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
