VPN issue, UC8.0
Answered Question
Jan 20th, 2010
  • Silver, 250 points or more
I´m having difficulties with split tunneling after upgrading to the 8.0 software pack. Anyone else have this issue? I can´t reach the network.. no ping reply from the UC.
My config;
crypto isakmp client configuration group EZVPN_GROUP_1
key <removed
dns 192.168.3.10 8.8.8.8
wins 192.168.3.10
domain tele-competanse
pool SDM_POOL_1
max-users 10
acl 109
crypto isakmp profile sdm-ike-profile-1
   match identity group EZVPN_GROUP_1
   client authentication list Foxtrot_sdm_easyvpn_xauth_ml_1
   isakmp authorization list Foxtrot_sdm_easyvpn_group_ml_1
   client configuration address respond
   virtual-template 1
interface Virtual-Template1 type tunnel
ip unnumbered Vlan1
tunnel mode ipsec ipv4
tunnel protection ipsec profile SDM_Profile1
ip local pool SDM_POOL_1 192.168.254.240 192.168.254.249
access-list 109 remark SDM_ACL Category=4
access-list 109 permit ip 192.168.3.0 0.0.0.255 any
access-list 109 permit ip 192.168.4.0 0.0.0.255 any
access-list 109 permit ip 10.2.2.0 0.0.0.255 any
access-list 109 permit ip 10.2.10.0 0.0.0.3 any
access-list 109 permit ip 192.168.1.0 0.0.0.255 any
Please help.
Eivind
Correct Answer by Steven Smith about 7 years 6 months ago
If you downgrade in CCA and CUE is downgraded, I believe CUE will be defaulted.  I haven't heard of any problems running CUE 7.1 and CME 7.1 together.  You should be fine with that.
Overall Rating: 5 (1 ratings)
Steven Smith Wed, 01/20/2010 - 11:58
  • Gold, 750 points or more
Hi Eivind,
I haven't tried this, let me see what happens when I do.
Steven Smith Wed, 01/20/2010 - 15:33
I am having some problems with my 8.0 system, let me look into this more.
Eivind Jonassen Mon, 01/25/2010 - 12:10
Hi Steven,
Any update on this???
I also saw that our UC reloaded due to software crash this morning. My guess is that the IOS has some bugs, is there any alternative IOS releases for the 8.0 version I can download???
Eivind
Steven Smith Mon, 01/25/2010 - 12:20
Hi Eivind,
Actually today, there is an update on this.  I spoke to some development and QA guys, and when doing split tunneling with EZVPN in CCA 2.2, it doesn't configure it correctly.  Bug was created last night on this.
CSCte60612:   after Split tunneling config, client can NOT reach UC500 behind
Workaround: delete FW and re-enable the FW include VTI interface as inside.
As far as the crash you experienced, I would recommend opening a case for it.  Alternatives for 8.0 are 7.1.3.  We are looking at getting another software pack out, but the time frame for this has not been established.  Let me know if this works for you.
Eivind Jonassen Mon, 01/25/2010 - 12:30
Well,
I´ve tried the workaround earlier, but the issue wasn´t completely resolved. I got some complaints from other collegues that they were not able to reach our file server when using VPN. This error occured every now and then.
I´ll try downgrading the IOS, should I expect any issue with the CUE if I downgrade the IOS??
Eivind
Correct Answer
Steven Smith Mon, 01/25/2010 - 12:51
Eivind Jonassen Thu, 01/28/2010 - 04:48
We are also experiencing software reload with this image. I've opened a TAC case and will keep you posted.
Eivind
Eivind Jonassen Thu, 01/28/2010 - 23:10
I've downgraded the IOS to uc500-advipservicesk9-mz.124-20.T2 and all issues are resolved.
The TAC case is SR 613515163 in case you wish to follow it.
Eivind
Related Content
