3560 -IOS upgrade- boot command query
Answered Question
Jan 20th, 2010
  • Gold, 750 points or more
Uploaded the 3560 with new IOS leaving the existing intact. Issued the boot command..
boot system flash:c3560-ipbasek9-mz.122-53.SE.bin;flash:c3560-ipbase-mz.122-25.SEE2/c3560-ipbase-mz.122-25.SEE2.bin
Show boot:
BOOT path-list      : flash:c3560-ipbasek9-mz.122-53.SE.bin;flash:c3560-ipbase-m
Config file         : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break        : no
Manual Boot         : no
HELPER path-list    :
Auto upgrade        : yes
Question is the boot path is fine to reboot the switch or need to be changed (no need of 'flash:' in boot system command..?)
TIA
MS
Correct Answer by Jon Marshall about 7 years 3 months ago
Show boot:
Enable Break        : no
Manual Boot         : no
HELPER path-list    :
Auto upgrade        : yes
TIA
MS
MS
The boot system command needs to know which filesystem the IO is on so you do need the "flash" part in the boot string.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 01/20/2010 - 12:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Show boot:
Enable Break        : no
Manual Boot         : no
HELPER path-list    :
Auto upgrade        : yes
TIA
MS
MS
Jon
mvsheik123 Wed, 01/20/2010 - 12:29
Thanks Jon. So the switch will use 'c3560-ipbasek9-mz.122-53.SE.bin' during reboot...
MS
Jon Marshall Wed, 01/20/2010 - 12:32
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
MS
MS
Yes, as long as that image is located in flash it will use it.
Jon
