AnyConnect login page - default group display
Jan 20th, 2010
On the AnyConnect login page is there any way to make a specific group be the default or is it simply an alphabetical sort and cannot be changed?
CHRIS YEO Wed, 01/20/2010 - 17:27
Are you referring to the policy groups?  These can be set by Radius.
Phil Williamson Thu, 01/21/2010 - 05:56
I'm not sure what you mean by your reply.
When my remote users browse to https://ASA_PubIP they get the initial AnyConnect splash page with username/password/group - the group defaults to an alphabetical sort it appears.  So when a user tries to authencicate, who is supposed to select group XYZ, but does not recognize that the default group is ABC their auth fails and we get a support call.  So can I make any particular group be the default as displayed on the login page?
busterswt Fri, 01/22/2010 - 22:45
I don't know if you can set the order persay, but you can assign an alias name to a group and maybe put a space or some other special character first so that it gets ordered first.
