01-20-2010 03:58 PM - edited 03-11-2019 09:59 AM
Hi All,
we are using ASA 5510 with two WAN links. I was trying to configure IP SLA to setup link redundancy. but with this mechanism, we can't use both link at a time, since ASA doesn't support PBR. Now we want to come up with static route to pass certain traffic from first link and other traffic from primary link. is it possible to achieve this configuration? for example pass all traffic from web and ftp servers from primary link and pass the rest from backup link.
any suggestion would be very appreciated.
Alex
Solved! Go to Solution.
01-20-2010 04:12 PM
Hi Alex,
This has been addressed multiple times in the forum. The ASA does not support dual isps or pbr, so it can't be smart enough to send traffic destined to one host out on one link and the rest on the other.
If you had a router outside and inside of the ASA you could configure pbr to get you past that obstacle.
But unfortunately the ASA cannot do it.
I hope it helps.
PK
01-20-2010 04:12 PM
Hi Alex,
I hope it helps.
PK
01-20-2010 04:21 PM
thanks PK.
do you have any document handy to show how to configure router in front of ASA to take care of two ISP?
thanks
Alex
01-20-2010 05:13 PM
Here is a link with examples:
Yes pls. read this thread as well:
https://supportforums.cisco.com/message/894921
-KS
