01-20-2010 04:11 PM - edited 03-04-2019 07:15 AM
What cable or devices are required to directly connect a 3845 ISR via a T1 WIC card to an 1841 WIC card to test the configuration prior to installation? I have both devices configured, but am unable to get a link light using a CAT 6, Cat 5e crossover, or flat cable from an old Adtran.
01-20-2010 04:30 PM
You would need T1 cross over cable.(Rj45)
Check out this site for specific pin configuration
http://www.ecst.csuchico.edu/~dranch/HARDWARE/common-cables.html#xover-t1
Also for where to buy your cable:
http://www.stonewallcable.com/product.asp?dept%5Fid=134&pf%5Fid=SC%2D9598%2DX
Reza
02-05-2010 06:20 AM
Made up a T1 crossover cable per the provide link and it worked, Thanks
