Outlook sync with Cisco personal directory
Jan 20th, 2010
We are using CUCM 6.1, just wondering if the user can sync the contact between outlook and personal directory. I found a plug-in pakage named TacSyncInstall on CUCM server, but don't know how to use it. Any suggestions?
Thanks. Leo
Overall Rating: 4 (3 ratings)
lionel.ndg Tue, 09/13/2011 - 19:28
I do have some issues pressing the Synchronize button after successfully installing the TabSyncInstall.exe
I am running on the cucm 8.6 version where by i download TabSyncInstall.exe from the plug in. installation was done on
windows 7(32 & 64 bits) . After input all the information: server IP,user id, password, i press the Synch button,
the Tabsync program hand and crash.
I intending to do a synch the address book on my Microsoft outlook 2010 exchange server with the cucm.
Anyone know why is it happening?
adrian.meighoo Fri, 03/02/2012 - 04:43
  Were you able to resolve the Tabsync crashing issue. We are having the same problem.
Thanks for any assistance.
Christin Varghe... Wed, 12/16/2015 - 01:54
As Mitch suggested,
This can be resolved by running the address book sync in compatibility mode for Windows 95. It will sync contacts in C:\Users\<user>\Contacts folder
Md. Rashedul Alam Mon, 03/05/2012 - 04:08
I am facing same issue at windows 7. For win Xp  Tabsync is working properly. Need help.
Mitch McGill Tue, 04/14/2015 - 12:40
I have been able to successfully sync if I run the tool on Windows 8 pro using Win 95 compatibility mode. the problem I had was that it was only finding Contacts that were added in the  C:\Users\<user>\Contacts folder. I have not put any time into trying to import these contacts from Outlook via a .csv file but this looks like it would be simple enough to do (import option at the top). I am looking now for 3rd party programs that can automatically sync the contacts and parse to XML in hopes I can just add this as a phone service.
Inder Manjit Singh Thu, 04/19/2012 - 13:35
Hi Jason,
This information is helpful to understand why Tab Sync is not working with Windows 7.
Do any Cisco TAC types know if a replacment for TAB Sync functionality using Windows 7 is in the works?
