power supply issue - WS-C6509
Jan 20th, 2010
We received an alert - PowerSupply_Fault_CiscoStack PWR-SWITCH [wscac2500w] is StateNotNormal. Indicates that the state of the power supply for this system is not NORMAL or SHUTDOWN."sh test" results are also attached. Can you please let me what is the issue here?
SWITCH> (enable) sh environment power
PS1 Capacity: 2331.00 Watts (55.50 Amps @42V)
PS2 Capacity: 0 Watt
PS Configuration : PS1 and PS2 in Redundant Configuration.
Total Power Available: 2331.00 Watts (55.50 Amps @42V)
Total Power Available for Line Card Usage: 2331.00 Watts (55.50 Amps @42V)
Total Power Drawn From the System: 683.34 Watts (16.27 Amps @42V)
Remaining Power in the System: 1647.66 Watts (39.23 Amps @42V)
Configured Default Inline Power allocation per port: 7.00 Watts (0.16 Amps @42V)
Slot power Requirement/Usage :
Slot Card Type           PowerRequested PowerAllocated CardStatus
                         Watts   A @42V Watts   A @42V
1    WS-X6K-SUP2-2GE     128.52   3.06  128.52   3.06  standby
2    WS-X6K-SUP2-2GE     128.52   3.06  128.52   3.06  ok
3    WS-X6348-RJ-45      100.38   2.39  100.38   2.39  ok
4    WS-X6348-RJ-45      100.38   2.39  100.38   2.39  ok
5    WS-X6348-RJ-45      100.38   2.39  100.38   2.39  ok
9    WS-X6548-GE-TX      125.16   2.98  125.16   2.98  ok
Slot Inline Power Requirement/Usage :
Slot CardType            Total Allocated   Max H/W Supported  Max H/W Supported
                         To Module (Watts) Per Module (Watts) Per Port (Watts)
3    WS-X6348-RJ-45      0.00              399.00             7.000
4    WS-X6348-RJ-45      0.00              399.00             7.000
5    WS-X6348-RJ-45      0.00              399.00             7.000
SWITCH> (enable) sh environment all
Environmental Status (. = Pass, F = Fail, U = Unknown, N = Not Present)
  PS1: .     PS2: F     PS1 Fan: .     PS2 Fan: F
Leo Laohoo Wed, 01/20/2010 - 20:47
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
How many PS do you have?
Jerry Ye Wed, 01/20/2010 - 20:53
  • Cisco Employee,
Looks like you have a PS failure. You need a replacement PS.
HTH,
jerry
d.muralidharan Wed, 01/20/2010 - 21:11
Can you please let me know why we are seeing the status to be OK under 'sh envir' & under 'sh test' we are seeing the power supply to hav efailed?
Jerry Ye Wed, 01/20/2010 - 21:16
  • Cisco Employee,
Can you post the output of those two commands? I am not seeing that on your original post.
jerry
d.muralidharan Wed, 01/20/2010 - 21:23
'Sh test'  results below:
SF5SW1>  sh test
Diagnostic mode: minimal   (mode at next reset: minimal)
  Chassis-Ser-EEPROM: .     Fan: .
  Clock(A/B): A         Clock A: .     Clock B: .
  VTT1: .    VTT2: .    VTT3: .
'Sh envir' results below:
SF5SW1>  sh environment power
Jerry Ye Wed, 01/20/2010 - 21:29
  • Cisco Employee,
In the show test
SF5SW1>  sh test
In the show environment
There is no power from the failed PS.
jerry
