IOS upgrade in 4506
Jan 20th, 2010
Hi All,
I'm not able to upgrade my 4506 switch.
problem is: my earlier IOS is in inbuilt flash & now I have uploaded my new IOS to Flash0. we have changed the boot sequence to flash 0 & after restart it goes to ROMMON.
Can u please let me know which command I need use or if any document is available.
Rgds
Ganesh
krishnakumarr Wed, 01/20/2010 - 22:10
Pl check the IOS using the command dir slot0:
For boot from  rommon mode
boot system slot0:
then check the config register values
should be 0X2102
regards
krishna
ganesh gandhi Thu, 01/21/2010 - 00:06
Hi Ganesh,
Thanks for the reply.
My requirement is simple
I have a new image in my Slot0:XXXX.bin
1. which is the command to change the boot sequence to slot0?
2. Do I need to change anything in config-register?
Ganesh Hariharan Thu, 01/21/2010 - 00:23
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi Ganesh,
Hi Ganesh,
Boot process involves two software images: ROM monitor and supervisor engine system code. When the switch is powered up or reset, the ROM-monitor code is executed. Depending on the nonvolatile RAM (NVRAM) configuration, the switch either stays in ROM-monitor mode or loads the supervisor engine system code.
Check  out the below link hope this will clear your query !!
http://www.ciscosystems.com/en/US/docs/switches/lan/catalyst4000/7.5/configuration/guide/boot.html#wp1019850
Ganesh.H
