01-20-2010 10:38 PM - edited 03-15-2019 09:09 PM
Dear All,
I m running CME 7.0. The issue which i m facing is that my telco is sending the incoming calling number as 38579206 (land line number ) skipping the first 0 the number should be 038579206. Similarly for the international number i m receiving the incoming number as 966507660387 but it should be 00966507660387. Also for the mobile number the receving incoming number comes as 507660387 but it should me 0507660387. Please tell me how i can overcome this issue. Please tell me what translation rules should be applied is this scenario.
Malik.
01-21-2010 01:08 AM
Its standard behaviour for the leading 0 to be striped by the telco.
You need to adjust the 'calling number' ? What I normally do is pre-pend '90' onto calls like this.
This means my users can call back these people without putting '9' for an outside line.
01-21-2010 02:49 AM
Hi Malik,
I normally use voice translation profiles and apply them to incoming voice ports. The example below will add a leading 0 to the calling number: -
voice translation-rule 1
rule 1 /^.*/ /0&/ - matches any incoming number and adds a 0 to the beginning
voice translation-profile INGRESS
translate calling 1
voice-port 0/0/0
translation-profile incoming INGRESS
The above will allow users to use redial directly from the received and missed calls directory, if you have to dial a 9 to access the PSTN then you will need to add this before the 0 on the translation rule.
Cheers,
Phil
01-22-2010 10:13 PM
Hi Phil,
Thanks for your reply. I really appreciate your effort. But the problem is that with your configuration it will add single zero for the local and mobile calls…but for international calls I need double zero…how can I fix it…please make sure that I need the leading single zero or double zero for the incoming calls…
Waiting for your reply,
Malik…
01-26-2010 07:57 AM
Hi Malik,
There's no way around this unless you know what calling numbers to expect, which is highly unlikely!
The only way around the problem is to ask the telco to send the complete ANI to you, they should be able to do this. I have never come across a Telco that doesn't send all digits of the ANI to the receiver.
Phil
