Building LAB: VMWare can help? How many servers?
Answered Question
Jan 20th, 2010
Hi All;
We decided to build a LAB in our company for the CVP and IPCC, as in the LAB there is no big traffic and agents so we need something basic and simple. I appreciate if someone to advise me for the following:
1) Can I put the CVP Servers, CallManager, and IPCC all in one hardware server?
2) Can I have the voice gateway and the vxml gateway on the same router or they have to be separated?
3) I heared that there is VMWare solution that enable me to have every thing virually, how much this correct? And is it possible to cover the voice gatewat and vxml gateway using the VMWare? If yes, then how the E1's will be connected? Or it will be just simulation?
Bilal
Since it its trivial to clone boxes in VMWare on an EDX server, set up a really good template server with all the Windows SRs, patches, i386, WMI, SNMP all the ICM and CVP installers, SRs and everything all copied to the disk, SQL Server installer, SR and so on.
Take you time and build a good template.
Then clone this for your Domain Controller, Router, Logger, PG, AW, CVP, WebView. Now it's easy to install what you need as no CDs need to be inserted, a huge time saver.
Don't restrict the way the product is installed - make it represent production. You will learn a lot more this way.
Geoff
Correct Answer by Muhammad Amir Raza about 7 years 5 months ago
AOA,
        Yes, using Vmware you can install and configure all IPCC, CVP and CUCM server on single box.
You can use same router as voice gateway and vxml gateway. Using Vmware you can create everything virtualy, that is correct but only for lab purpose not for live deployements. For virtual voice and VXML gateway you can use GNS, no physical E1 termination but you simulate calls.
Muhammad AR
Overall Rating: 5 (2 ratings)
Correct Answer
Muhammad Amir Raza Thu, 01/21/2010 - 02:21
  • Silver, 250 points or more
AOA,
Muhammad AR
Correct Answer
Geoff
