Client disconnection
Jan 20th, 2010
I configured wireless Controller 4402 and 1250 s access points with EAP-PEAP authentication ,(ACS v5) patch 8 installed
The problem is the wireless clients disconnected and re authenticated so the costumer not accepted this issue
Please advice
iibesis Tue, 02/09/2010 - 01:56
What EAP PEAP authentication do you use ? EAP TLS, MS-CHAP ?
Br,
Joel
rtgregory Fri, 02/12/2010 - 10:11
It may be that have to enable spanning-tree port
fast on the AP switchport.
George Stefanick Fri, 02/12/2010 - 10:54
Im unclear as to your issue. They disconenct when they roam !? If so and you are using 802.1x you want to insure you use CCKM or WPA2 AES which uses PKM.
Trending Topics - Security & Network
