01-21-2010 12:24 AM - edited 03-06-2019 09:23 AM
Dear all,
Do you know how to force GLBP to forward all traffic of a specific PC in a LAN to a specific gateway/router ? That means to override GLBP loadbalaning
haris
01-21-2010 12:36 AM
glbp group load-balancing host-dependent
might be the way.
See http://www.cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/ft_glbp.html#wp1044078
But my understanding is the particular host will always use the same router as the gateway, but you have no chance to configure which one - it's somehow calculated by the GLBP group based on the PC MAC address.
So you configure you GLBP group, connect your PC and observer which gateway it takes.
As long as the number of GLBP group members remains unchanged (not sure what happens if one of the routers is powered off), it will always take the same router.
Does this help?
BR,
Milan
01-21-2010 12:44 AM
Dear all,
haris
Hi haris,
For your query host-dependent Specifies a load balancing method based on the MAC address of a host where the same forwarder is always used for a particular host while the number of GLBP group members remains unchanged.
Ganesh.H
