how to change the message in CUCM 7.0 " Your Current Options"
Jan 21st, 2010
Dear All
can any body help me or assist me to type my own message at the botom of the phones by default its your current options but i tried to much to change it or find any way to change and i failed.
in Call Manager express it was easy to change just at the cli you type "system message Hello this is your IP Phone" but at the CUCM 7.0 i dont know how to change this and solve this problem so can any body tell me how to change this message please its needed 100% for me
i have atached the picture that where the message cames so you people can see it.
with regards
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Waisudin Farzam ویس الدین فرزام
Project National IT Specialist            متخصص ملی تکنالوژی معلوماتی
Sustainable Development of Natural Resources Project
IDA Grant No: H238-AF
Program Management Unit (PMU)
Afghanistan Geological Survey (AGS) Annex Building, Ministry of Mines,
Kabul, Afghanistan
AWCC Cell Phone:                              0093 - 700 - 29 60 62
MTN Cell Phone:                                   0093 - 777 - 29 60 62
E-Mail Address:                                     [email protected]
Skype ID:                                               wais.farzam
MSN ID:                                                  [email protected]
Jaime Valencia Thu, 01/21/2010 - 04:12
You cannot change it, in CCM it was possible due to it being Windows and you had access to all the files.
CUCM does not grant access to the necessary files for this unless you have root access and it's not granted for purposes other than troubleshooting or to apply a workaround from a bug.
If this helps, please rate
