ACS 5.1 AD Groups not displayed
Jan 21st, 2010
I´ve succesfully joined the ACS 5.1 Server to a Windows 2003 Domain. But no AD Groups are displayed in the selection box.
Any suggestion?
Thank You!
Greetings
Rouven
Overall Rating: 4 (1 ratings)
Oscar Cardiel Tue, 02/23/2010 - 10:08
Hi Rouven,
sorry, It is now, I have the same problem....
regards,
Oscar
spirotsares Tue, 06/15/2010 - 09:48
I experienced the same problem and worked with tac until they pointed me to a patch to fix this bug:
bug CSCtf39158 -Can't retrieve AD groups in single forest with multiple trees scenarios
Patch filename: 5-1-0-44-3
I applied patch and everything now works as expected.
I would contact TAC to ensure you're experiencing the same issue as I was before deploying the patch.
Jatin Katyal Tue, 06/15/2010 - 18:13
  • Cisco Employee,
Download from: CCO / Support / Download Software  http://www.cisco.com/public/sw-center/index.shtml
Select: Security / Identity Management / Cisco Secure Access Control  System / Cisco Secure Access Control System 5.1 / 5.1.0.44
##Steps to create repository##
Go to the CLI mode of this ACS
Create a repository (it's basically defining FTP server)
AAA/admin(config)# repository FTP ---> (could be any name)
AAA/admin(config-Repository)# url ftp://
AAA/admin(config-Repository)# user password plain
Steps to Install the ACS 5.1 patch:
Issue the following acs patch command in the EXEC mode to install the ACS patch:
acs patch install patch-name.tar.gpg repository repository-name
Rgds.
JK
Do rate helpful posts-
