LMS 3.2 Archive Management DCMA0055 failure
Answered Question
Jan 21st, 2010
Hey,
we have Cisco Works LMS 3.2 and its registered with ACS 4.1.4(13).
If I want to go to RME/Config Management/Archive Management, I get the following error:
"DCMA0055: CM0039 Error in SQL execution. SQL code 8405 : MESSAGE: SQL Anywhere Error -210: User 'DBA' has the row in 'DCMA_Archive_Status' locked"
Can anyone help me to find the cause of this message?
We updated LMS from 3.1.1 to 3.2  about 4 weeks ago and its running fine so far.
Last time this error occur, we updated our ACS. After I restarted the daemon and re-register it with the ACS the error were "fixed".
Btw. today there were no changes on the ACS.
So is there a way without restarting the daemon manager?
Thx,
Patrick
Correct Answer by Joe Clarke about 7 years 4 months ago
Another background archive management job may have been running, even if you were the only user logged in (e.g. config collection or polling).
Overall Rating: 4 (2 ratings)
patrick.peuten_2 Thu, 01/21/2010 - 08:24
Hey,
the error message doesn´t appear at the moment.
Now I can go to the Archive Management.
I only started some NetConfig jobs in the last minutes, maybe they fix the error ^^.
Any ideas?
thx,
Patrick
Joe Clarke Sat, 01/23/2010 - 10:22
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This error could very well be transient.  If one were trying to do two config archive operations at the exact same time, it is possible a lock contention issue could be encountered.  I don't think this is something you should see too often, though.
patrick.peuten_2 Sun, 01/24/2010 - 11:50
Hey,
thanks for your reply Joe.
I don´t remember clearly, but I think I was the only who logged in LMS.
The error message appear about 10 - 15 minutes, everytime I clicked on Archive Management, so I don´t think that I or another person started a Archive Management task at exact the same moment.
Anyway, I will keep an eye on it
Thx & bye,
Patrick
Correct Answer
Joe Clarke Sun, 01/24/2010 - 13:29
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Related Content
