Sending Caller Name ID w/ External Mask - CM 5.1.3
Jan 20th, 2010
Hello All,
I have a facility that consists of two seperate operating groups sharing the same CM 5.1.3 and ISDN network. One group is okay with their external number mask displayed on out going calls, the other group requires their name and number displayed to the customer. Because they share the same network, I'm not sure that this can be managed by the network provider... My question - - -  Are there settings that I can define at the station level allowing some stations to send the name ID, and others will not?
Thank you in advance for your assistance.
