Enabling https on 2950G switch
Jan 21st, 2010
I upgraded one of our cisco 2950  switch with the IOS image :c2950-i6k2l2q4-mz.121-22.EA13.tar .
After upgradation ,enabled ssh v2.
Its accessible through ssh, but I want enable https to view the web inteface.
I tried using the cammand " ip http secure-server", but its not working on this IOS image.
Please suggest how to enable https for web-console.
Itzcoatl Espinosa Thu, 01/21/2010 - 11:19
I am not completely sure if you can do it, but I think you could try the following.
To secure the http server you can configure the following commands:
"ip http access-class"
Here is the information of the command.
http://www.cisco.com/en/US/docs/ios/12_2/configfun/command/reference/frf005.html#wp1020068
"ip http authentication"
http://www.cisco.com/en/US/docs/ios/12_2/configfun/command/reference/frf005.html#wp1020124
I hope it may help
Itzcoatl Espinosa
milan.kulik Fri, 01/22/2010 - 02:47
what's your IOS feature set?
Isn't  it a Crypto Image?
You need
C2950 EI AND SI IOS CRYPTO IMAGE AND CMS FILES then.
If I remember correctly, an http file structure is necessary on your Flash for a web access to work.
If I'm correct, http access is also not working on your switch currently, is it?
HTH,
Milan
manjit_raulo Fri, 01/22/2010 - 13:55
Hi Milan,
As u can see in my discussion..... I already mentioned that I enbaled ssh..that means its a crypto image.
If it was not a crypto..then I cud not be able to enable ssh.
For your clarification....if I disable ssh..then http is working.(As i used the CMS file..i.e tar file of the IOS image to upgrade)
But if I enable ssh......http wont work,,,,as it requires secure connection.....for this we have to enble https by using the command "ip http secure-server".
The problem is that.....the above command is not supported on this current image.....so I want to know that if there is any different way to enable https, then pls suggest.
