Scripting - route calls to voicemail
Answered Question
Jonathan Schulenberg Thu, 01/21/2010 - 11:24
Use the dequeue step to remove them from the CSQ and then a call redirect step pointing to a DN in UCM which is configured to CFA to
it's voicemail box.
Jonathan Schulenberg Thu, 01/21/2010 - 12:19
@Geoff-  My thoughts exactly.
There are several. One would be to just mentally count up how long it takes to make it through the Queued loop once. Then multiply that out until you get to two minutes. Add an iterator and increment it each time through the loop. At the start of the loop have an If step that checks to see if the iterator is GT a certain value. Another would be to use the Get Reporting Statistics step to find the amount of time the contact has been waiting.
