Using IP Routing
sjoberg37
Hello all i am new to the cisco support community.
I have a bit of trouble in one of my cisco college classes, so i was hoping the community here could help. See our teacher has told us to mock up a network using packet tracer. We must connect a server, two routers, then a switch hooked up to four computers. The problem is none of us have any prior knowledge of how, and he didn't give us any instructions or help. I have connected everything, but i am having trouble with the routers. I am almost certain i have to use the Ip route command on the 1841 routers, i just have no idea how to use it.
Here are a list of my ip addresses:
Server - 192.168.254.254 /24
to Router 1- 192.168.254.253/24
Router 1 through serial connection - 10.10.10.6/30
To Router 2's Serial - 10.10.10.5/30     These are all same subnets
Then from Router 2's Ethernet i am hooked up to that switch and four computers
which is 172.16.255.254
I am able to ping every computer and Router 2 from one of my end computers. My problem is once i try to ping the outside address of Router 2, it's unreachable, so from any computer i cannot ping 10.10.10.5 or anything beyond to Router 1 or the Server. My question is how would i use ip route to connect this network? We have had no instruction or training on this and any help would be greatly appreciated! if anyone helps, thanks in advance!
If my picture doesn't explain it correctly or if you need more detail i can upload the picture again with captions, thanks!
sjoberg37 wrote:
Oh well im almost sure my addressing is correct, i just checked it again. But when you told me the ip route commands for router 1 and router 2, my R1 and R2 were the opposite routers. unless i assumed wrong and i am supposed to be doing exactly that. I keep getting the invalid next hop address. sorry for the confusion i am still really new at this!
Jake
On the router that connects to the server -
ip route 172.16.255.0 255.255.255.0  10.10.10.x  (where 10.10.10.x is the other routers serial interface IP)
on router that connects to LAN switch -
ip route 192.168.254.0 255.255.255.0 10.10.10.y (where 10.10.10.y is the other routers serial interface IP)
Jon
12 Replies 12
Jon Marshall
On router2
ip route 192.168.254.0 255.255.255.0 10.10.10.6
on router1
ip route 172.16.255.0 255.255.255.0 10.10.10.5
Jon
ahh thank you! but i have a problem, it says it wont work because "it's this router", any other suggestions something i mightve missed? thanks for helping me now im getting somewhere
Jake
If it's saying "its this router" it means the next-hop you are entering is an IP assigned to an interface on the local router. Are you sure your addressing in the first post is correct ?
Jon
Jake
Jon
jon.marshall wrote:
Jake
Jon
Oh ok i have done that thank you very much! I had no error messages so i am assuming it worked. Now since it does work and i am not able to ping past the router still, is this because of a previous error? because if the addresses are correct it should all work out now right? and thanks much!
sjoberg37 wrote:
jon.marshall wrote:
Jake
Jon
Jake
Can you post configs of both routers
Jon
Sure no problem, here are three images showing the ip addresses and the ip routing . I hope I did this right
Jake
Jake
From R2 can you ping the server ?
From R1 can you ping the server
Can you do a trecroute from a client to the server
Jon
Alright from R1 i can ping the server, but R2 i cant. It seems that something is wrong with the connection between R1 and 2, i just don't know what it is. I dont think it is the subnets, the ip addresses seem to be right. When i did a trace route it couldnt go past R2, so there is something stopping everything from that ethernet port.
Jake
Jake
Does the server have the correct default-gateway configured on it ie. 192.168.254.253 ?
Jon
A ha! You were correct! the only problem was one of the clock's speed was not set! thank you very much for this! it is all configured!
