The difference between SSL & TLS
hanyawad
dear experts,
i need to know The difference between SSL & TLS and in which situations i should i have to use them.
thanks
Labib Makar
Steven Ochmanski
Labib,
At a 10,000 foot level v3.0 was superceded by . v1.0.
TLSv1.0 (RFC 4346) was an upgrade to SSL v3.0 (but they don't interoperate)
This "Cisco.com document" describes the workings of both in some detail:  SSL: Foundation for Web Security
it states this as some basic differences:
TLS uses slightly different cryptographic algorithms for such things as the MAC function generation of secret keys. TLS also includes more alert codes.
Also See: Wikipedia TLS
As far as which to use, it would depend on if both sides (server/client) support each?  TLS v1.0 or v1.1 is newer.
Most modern Browsers tend to support both.
i.e.
  • Firefox 3.5.7 supported both SSL v3.0 and TLS v1.0
  • Internet Explorer v6 supported both SSLv2, SSLv3, TLS v1.0
  • etc.
Hope that helps.
Steve Ochmanski
Steven Ochmanski
Labib,
i.e.
  • etc.
Hope that helps.
Steve Ochmanski
ptamakuw
Did you find proper answer of your question? I am still looking for right answer... and also what is the header difference between SSL and TLS ?
